Optimal peak height for IC quantitation
Hi, I'm using an ICS-2000 running Chromeleon 6.8.
I was experimenting with the signal-noise measurements when I thought of a question:
For quantitation purposes, what it the maximum/optimal peak height you want to aim for? Too high and the peak could flatten at the apex; too low and you'll have to high of a signal to noise ratio.
Thanks!
Two possible answers here, depending on how you propose to adjust peak height.
If you are injecting a given amount, and propose to change peak height by changing the display settings, it doesn't matter (unless you doing manual peak measurement from a printout). The display is simply for informational purposes and can go off-scale without affecting the actual data processing.
If you are changing the amount injected, then so long as you are withing the linear range of your method, it should not matter. The linear range must be determined experimentally by injecting standards at various levels (this is normally part of method validation). The scenarios you describe (peak shape distortion at the high and and poor S/N ratio at the low end) represent the limits of the range.
Users browsing this forum: Semrush [Bot] and 13 guests
