Sensitivity of lc-ms/ms sysytems
can any one tell me which of the following system is best in terms of sensitivity and reproducibility
1)AB SCIEX API 4000
2)WATERS MICROMASS QUATTRO PREMIER XE .
Waiting for your comment
shashank
I have used both.
If using reserpine (+ESI) as the sensitivity check standard, they are vitually the same with 4000 slightly higher.
Premier XL polarity switching delay (+ to -) is 20ms vs 700 ms for API. Premier maximum scan rate is twice that of 4000.
API can use shorter MRM dwell time
Reproducibility is sbujective to individual opinion or instrument.
Users browsing this forum: Bing [Bot], Semrush [Bot] and 2 guests
