Help re Analyst Software
I am trying to analyse my LCMS data using Analyst, but was somehow getting a different interface or something in the same software in another computer.
I re-installed it and can now see the same interface, but am having problems regarding quantitation.
How do I set the program such that the analyte/IS peak area is shown in full numbers and not a number to the power of something? e.g. 29853226 and not 2.99e+0007.
Or is there even such settings?
Wan
I have my columns set and saved as a template that I copy from project to project, so I haven't modified them in a while. You should be able to right-click on the top box or the area above the table and select "columns" or "edit columns". It's just a matter of deselecting the scientific notation check box and saving the settings.
Be aware, that there are different user profiles in Analyst, and if you are not in a specific group, you will not be able to change the columns. Since you installed this yourself, I am assuming that you gave yourself the most right possible.
Thank you for your help! I've found the options to select the no. of sig. figures and uncheck the scientific notation box from what you mentioned. :)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 3 guests
