Agilent 1100 and Qtrap it work with MeOH but not with ACN
Posted: Wed Apr 21, 2010 8:05 am
Dear all,
I really hope somebody could come with one idea because I don’t know what else can I do!!
I have use a method for the detection of 15 compounds for four months. But the other day, I don’t know why it stops working.
I thought it was the MS but the MS work as when I infuse the standard with a syringe using the same HPLC method it work. If a put 100 % MeOH with formic cid the system Works perfectly, however if I use 100 % ACN with formic cid it doesn’t work…I mean I don’t detected anything.
I change the mobile phase locations, canals, I have changed the columns, I have injected without columns and without pre-columns, but the system only Works with MEOH. I have check if there are leak but there are not. ….So I don’t know what else to do or what else to try
. I will really appreciate any comments or suggestions.
Carol
Carol
