Drylab retention simulation-ternary mobile phase
Posted: Wed Apr 28, 2010 7:46 am
Hi, dear all,
In Drylab simulation software an isocratic ternay mobile phase mode is available, and I know the simulation analog is based on the linear logarithm of retention factor(k') versus organic modifier strength(B%) in binary mobile phase, but what's the analog is appropriate for ternary mobile phase mode?
And this simulation software supplies an approach for ternary mobile phase prediction: First, carry out two binary mobile phase run with different modifier strength(as Run 1 and Run 2) and produces the corresponding retention, then mixes the above two binary solvent mixtures with equvalent volume(1:1) to make a ternary mobile phase, which generates different retentions(Run 3), finally those peak parameters are inputted into the software and makes the Resolution-Retention Map, so what's idea leads to this approach? Information, if any, be appreciated greatly! Thanks in advance!:)
Austin
Austin
