for my degree work
good afternoon, as I told you I'm trying to develop an HPLC method validation for amino acids, I can not separate the histidine from serine and aspartic acid from glutamic acid, the gradient have changed many times and I've failed, what else I can do, thanks.
Try different columns. There are quite few manufactures make column specific for AA, like Tosh(?). If you use heavy matrices, separating all of them is a tough task.
Try ion-pairing reagent with any C18 column, or alternatively try mixed-mode Primesep HPLC column:
http://www.sielc.com/compound_002.html
Contact me if you have questions.
Vlad Orlovsky
HELIX Chromatography
www.helixchrom.com
In total there are 24 users online :: 1 registered, 0 hidden and 23 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 23 guests
