Which statistic test is best for this hplc measurment ?
Hi , i have standards ( 1-100 ppm ) and in each concetration my analyte was treated at four different treatment
so concetration 1 has treatment 1,2,3 and 4
concentration 2 has also four treatment
which test can i use because if i use ANNOVA that's mean that i will test only one concentration at different four treatments but what i need to do is to test all conc. not only one and say that all four treatments show no different in the four treatment with all concentration ? how ? which
please help me thanks :)
ANOVA is the way to go, but you need a 2-way ANOVA, and check only for one effect.
Ace
Conduct an F-test (ANOVA) on the four treatments for each conc'n Class separately. You will end up with an F-statistic that says either "there is no significant difference between the variance in values due to treatments-- trt 1=trt2=trt3=trt4" or "at least on treatment gives a significantly different response compared to the others". If so, Then inspect the values and variance---more than likely you will see a noticeable in the response values diff between treatment 1 vs treatment 4. Then, simply followup the comparison of trt 1 vs trt 4 with a Post Hoc test to substantiate the visual difference in a quantitative manner.
Jumpshooter
Guys can illustrate more please because i still don't get it :oops:
it is easy to say at 1ppm the four treatments show no different but do i need to test each concentration individually ? is there is any examples in the internent or some books i will be very gratefull
Just google: "2-way anova example", the first hit:
http://www-stat.stanford.edu/~susan/cou ... xanova.pdf
The paper shows how to do it by hand or by using R (www.R-project.org).
Ace
In total there are 18 users online :: 0 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 18 guests
