Varian Saturn 2000 Tune problem
When attempting autotune, I am getting error message during electron multiplier setting that there may be too many ions in the trap. How do I reduce the number of ions in trap?
Make sure your column oven temperature isn't too high when trying to tune, also put a split on your injector. If that fails, you might try baking the trap overnight but you will likely need to clean it if the first two ideas fail...
Users browsing this forum: Bing [Bot], Semrush [Bot] and 2 guests
