TLC FID iatroscan peaks not separating
Posted: Fri Feb 20, 2026 7:27 pm
Hi all, looking for some input about issues with our Iatroscan MK-7S. We are running a super standard with 6 lipid classes but the resulting peaks are not well resolved. Also, the blank/origin scan that should clean the chromarods between scans is not thoroughly cleaning the peak off the origin.
We have tried troubleshooting with different lipid concentrations, development solution ratios, development time, and so on. The software we are using is called Easy Chrome.
Ideas would be much appreciated!
