Current cost of a PM forAgilent 1100 system w one detector
What is the current price for a OEM PM for a Agilent 1100 full stack with one detector
There are so many possible configurations that 1100 "stack" does not provide anyone with enough info to suggest a number. You will need to provide the exact module model numbers, serial numbers, any installed options (e.g. SSV, separate valves etc) which CDS (Rev#) you use, location etc for a quote. Contact Agilent for a quote. The cost is based on location and which modules you have. NOTE: A "PM" service is not a repair service, it is routine maintenance. If there is anything wrong with your system, then the repairs would need to be completed first.
*I DO NOT WORK for AGILENT, but do know a lot about their systems.
If Agilent even still services the 1100 series. May need to try 3rd party.Contact Agilent for a quote.
Users browsing this forum: Google [Bot] and 13 guests
