Time to clean ion source?
Posted: Thu Jun 03, 2010 2:00 pm
Hi all,
After using our Shimadzu QP2010 for more than 6 months. I noticed one time our baseline stayed flat at zero instead of the typical increase in baseline from column bleeding from our temperature programming. sample peaks signal was also very very low.
This happen just after we've done inlet maintenance and the usual leak checks . Tuning results was still okay.
then as soon as I called the technical service man to have a look and injected a sample to show him the problem the system went back to normal
. we can see our usual sample peaks with the expected peak signal strength and the raising baseline just like before.
Can a dirty Ion source cause this to happen since we haven't done any ion source cleaning yet?
Tarapan
Tarapan
