Split or splitless injection for complex mixtures like oil
Posted: Thu Jul 01, 2010 4:43 pm
Hi all,
Someone told me that splitless mode is better for complex mixtures like oil compared to split mode. He gave the logic that due to different boiling points, not all compounds get volatilized at once and the split valve remains open all the time so more volatile compounds might escape before the entering the column. And the fraction which enters in the column is not representative of what is actually in the sample
Is this true?
What are the pros n cons of using splitless versus split mode for complex mixtures?
Further, I have straight crude oil samples and water column samples (which could have trace levels of hydrocarbons). I am thinking of using split mode for straight oil and splitless for water samples. Then we compares chromatograms for quantitative purpose. But again, someone told me that that could give some error in quantitative comparison between straight oil and water samples.
I will be grateful for your insight.
Also. i would appreciate if you refer me to the literature.
Best regards,
Best regards,
