GPC problem, help
I have a Styragel HR1 Column (THF). Methanol was used as eluyent by mistake for about 3 hours. Now I don't obtain good resolutions, probably the column is damaged.
Is it possible to fix it? Thanks.
Dory
If it does not perform any more after being converted back to THF, it is probably dead. Polymeric packings swell and shrink significantly as a function of the solvent. THF is a swelling solvent, methanol will shrink the packing.
In total there are 21 users online :: 1 registered, 0 hidden and 20 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 20 guests
