HILIC of nitriles
Can I use HILIC in order to analyze alyphatic nitriles?
For instanse TMSN- tetramethylsuccinonitrile.
I doubt it, especially using acetonitrile in the eluent. Your nitrile will likely not partition from an acetonitrile rich phase into a water rich one.
Could possibly work using acetone or some other exotic (for HILIC) organic solvent.
Petrus Hemstrom
MerckSequant
Umea, Sweden
what is your K using a RP column?
based on this example product why choose HILIC?
have you thought of going for a column that separate based on the effect to the Pi orbits.
In total there are 20 users online :: 1 registered, 0 hidden and 19 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 19 guests
