Robustness testing - wavelength variation
Hi all,
In the valiadation of a stability-indicating assay and impurities methods,
what acceptance criteria do you all normally apply to robustness results? Also, do you normally evaluate wavelength as part of robustness testing, and if so, what range do you usually evaluate (e.g., +/- 2 nm)?
Thanks!
Hi all,
Thanks!
WV is not included. It should be calibrated routinely in PM, PQ.
I was wrong, how about 2% variation?
In total there are 19 users online :: 1 registered, 0 hidden and 18 guests (based on users active over the past 5 minutes)
Users browsing this forum: Semrush [Bot] and 18 guests
