RSD % of amino acid analysis (post column)
Hi all,
Anyone run post-column analysis of amino acid could please tell me what is the RSD% of the replicate results. That does not include sample prep.
Just roughly.
Thanks for any input.
Based on Information from a multi-lab study we participacted in through the American Oil Chemist's Society (AOCS).
Labs using Post-column derivatization reported RSDs in the following ranges:
Intra-sequence (triplicate) 0 - 27% depending on residue and sample type.
Inter-sequence (n=6) 0 - 24% depending on residue and sample type.
Labs using Pre-column derivatization reported RSDs in the following ranges:
Intra-sequence (triplicate) 0 - 15% depending on residue and sample type.
Inter-sequence (n=6) 0 - 13% depending on residue and sample type.
Thanks for your reply.
In case, we use run standards, everything is fine, so what would the RSD expect to be. Anyone have run this kind of analysis?
In total there are 15 users online :: 0 registered, 0 hidden and 15 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 15 guests
