HILIC v/s RP HPLC
11 posts Page 1 of 1
Hi all,
I am a very basic user of LC. My experiment aim is nucleotide separation from serum. What basic difference is required for me to decide if I should use HILC or RP HPLC? I guess they are almost opposites of each other, but what kind of properties should my analyte have?
Cheers!
Are you sure you are looking for nucleotides? Or are you looking for the bases, or nucleosides (bases with sugar)?
Yes, I am targeting nucleotides and looking for adenine, guanine etc. However targeting and getting bases + sugar, won't harm either.
10 mM ammonium acetate, pH 5.0 on Atlantis T3 from Waters (a water wettable C18 with maximum retention), gradient to the same with 6% acetonitrile.
http://www.waters.com/webassets/cms/lib ... a60208.pdf
You can manipulate the pH for getting a suitable separation for the specific analytes that you are targeting.
For the bases with sugar, you will be better off using a HILIC technique. I will see what I find...
Here is the applications booklet for the Atlantis columns, including Atlantis HILIC. You will find a starting point for your application.
http://www.waters.com/webassets/cms/lib ... 0472en.pdf
This is the applications book for the BEH Amide column, again with some applications that can bet you started. This column is the best choice for HILIC applications, since it is most retentive.
http://www.waters.com/webassets/cms/lib ... A64081.pdf
http://www.waters.com/webassets/cms/lib ... a64069.pdf
doc 21
here is a link for an article on your subject:
http://www.dionex.com/en-us/webdocs/864 ... s-hplc.pdf
doc 21
This is a very useful article!
Thank you so much. :D
I read this article and i like it.
It describe very deeply so there is no problem about any query. It is really useful to me.
Great!
[url=http://www.r4card.com.au/]m3i zero[/url]
It is very useful for me because I am working this kind of project and it is really helpful to me. I have read all the things in deep and I am impressed with that. Its really good work.
[url=http://www.hairhut.org.uk]Hair Clip[/url]
I was trying to access the link and read the article, because I am also interested in the topic, but it says “Page not foundâ€
[url=http://photonic-sourcing.com] Photonic B2B Market [url]
I think this is the same article...
http://www.dionex.com/en-us/webdocs/864 ... mology.pdf
Users browsing this forum: Bing [Bot] and 1 guest
