retention time related guard column
hi, guys:
thank you all for helping me to solve the problem about back pressure. now I have a question about the retention time:
the retention time for same solution on column directly and column with guard column are same. why?suppose there should be some differences due to the total column lenth .
welcome any explaination :?:
Actually, it should be longer by the increase in column volume. If you have a small guard cartridge, the differnce may only be a couple of percent.
Users browsing this forum: Google [Bot] and 12 guests
