Analyzing PMIDA in water
Hi There
Any one who has experience with analyzing PMIDA (Gylphosate impurity) in water samples? LoD 0,1 ppm
Best regards
Breinbjerg
If HPLC is the method of choice I would start with a HILIC column.
Thanks - I'll try that.
Regards
Bo
Here is method for analysis of glyphosate and related products. Method is LC/MS compatible, so LOD/LOQ should satisfy your needs:
http://www.sielc.com/application_185.html
I am not sure that with UV or ELSD you can achieve detection limits of 0.1 ppm
Users browsing this forum: Semrush [Bot] and 13 guests
