So I've had this old pump in storage for at least 10 yrs
...probably more like 15 & I've never even so much as turned it on. I got it in a pile of equipement from an aquisition the company made and it was old then, but I thought I would hold onto it just because it looked so similar to the nice 600's I was working with at the time.
Fast forward to today: I'm reading a couple of papers that entail some post column derivitization and I pretty much have all of the equipement I need, but a little isocratic pump would be ideal for reagent delivery and I remember that little ancient orphaned pump.
It's a Waters 590, circa 1980 or so.
Long story short, I go deep into the bowels of the basement, find the little beast, clean it up a bit, and power it up.
It actually seemed happy to be alive.
OK, the electronics work. So I give it a few minutes to warm up then loosen a few compression screws and push some methanol through with a syringe until it's good and wet all over, then gave a shot at priming. Hey! It seems to be pumping smoothly and it'll push a nice stream at 5 ml/min, so I back it down to ~ 1 ml/min and install a column.
Pressure ripple is ~10 psi at ~900 psi. Really??
OK. Check flow rate with column installed:
Set rate 2.000 ml/min. Pressure: ~1750 psi.
Observed flow rate: 1.93 ml/min and running smooth as a baby's bottom.
Nice! Free pump for me - and oddly I like the SS piston indicator rods on the thing...they look a bit more macho than the standard 600 fare...
Thanks to whomever worked at Waters 30 years ago and built that pump!
I'm working with some waters 510's at the moment and they're as reliable as anything I've used previously.
I resurected two from a ~3 year hiatus on a lab bench, powered them up and, in flow testing (individually and as a binary unit) got <2% variation from nominal flow. :D
Good judgment comes from bad experience, and a lot of that comes from bad judgment.
If had similar experiance, but with a 64 pump from Knauer. Pump was 15 years old, always used for students at Botanic institute of Wuerzburg university. To help them out I did maintenance on that pump, and it is still runnign, so far I know. That was 21 years ago.
I used to use an old Beckmann Gold system until 2005 when I changed groups. The system ran well and was an absolute godsend to our group.
In total there are 26 users online :: 2 registered, 0 hidden and 24 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Google [Bot] and 24 guests
