Separation polyethylene glycol
Dear All
Why there is no separation for the polyethylene glycol (PEG) in GC? Is that due to the high molecular weight itself? Is any method can use to separate it?
Thanks & Regards
Pang
If it's a small enough PEG, one can obtain GC separation readily. We make trimethylsilyl derivatives here, use nonpolar capillaries.
Flash chromatography and thin layer chromatography can separate a molecular weight distribution of PEG. If the MW is too high it is not volatile enough to elute from a GLC column or the temperatures required are too high.
best wishes,
Rodney George
In total there are 30 users online :: 1 registered, 0 hidden and 29 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 29 guests
