Water content
Dear all
I need to clarify one thing. Is it the water content will affect the purity of solvent??? Yes or No.
Thanks for your kindly reply.
Pang
Hi
Your question (quite basic if I may add) is not a yes or no answer, the answer is: It depends on the detector you use. If you compare the FID, ECD, TCD and NPD you will find your answer.
