75% methanol in water using phosphate buffer Ph=3 , 25 mM ?
Hi , Tom and every one :D
Is my preparation correct ? :
Buffer preparation : in 1L volumeric flask put
1- 50.00 ml of 0.5 M tetrasodium pyrophosphate
2- 57.75 ml of 1.00 M phosphoric acid .
Fill up to 1L by water .
so now 75% methanol in water with buffer of phosphate at 25 mM can be done as the following in 900 ml flask :
675 ml methanol was put in 900 ml flask + 225 ml fromthe buffer that was prepared in 1L ( because i want to be buffered at ph=3 ).
Any help will much appreciated
Check out
http://www.liv.ac.uk/buffers/buffercalc.html
Why do you use pyrophosphate? How fast does that hydrolyze to phosphate? Normally one would use phosphoric + NaH2PO4 for this buffer.
A quick head calc tells me you have ~ 0.1 M aqu. solution, why that 57.75ml phosphoric?
If you think that you have ~0.025 M solution in the final mixture than you are wrong, as 675mL MeOH + 225mL aqu. solution does not give 900mL.
Hi
becase i use this calcuator
http://www.chembuddy.com/?left=Buffer-M ... reparation
it gives me this amount that i mentioned , but why 675mL MeOH + 225mL =900 ml !! .
What is the correct way to prepare 75% methanol in water but i need it buffered at ph=3 .
thanks
