what's quasi-binary mixture
Hi, everyone!
I read a literature and some words puzzled me:
Straight line approximations can only be used for quasi-binary mixtures, i.e. ternary mixtures in which the ratio of the volume fractions of the two organic modifiers is constant.
Woops, I'm confused, what the relationship between the quasi-binary and ternary mixture on earth? Can anyone give me some information, thanks in advance! :o
The God had ever have three apples. Adam was tricked eating up one of them in Eden, and the second dropped from the tree and hit Issac Newton on his head, then what happened on the third one?Interestingly it was bit by Steve Jobs!
Imagine a binary system where the A reservoir contains water and the B reservoir contains a 1:1 mix of ACN and MeOH. If you set the system to blend 50%B (i.e., a binary mixture of A+B), you are actually using a ternary blend of 50% water, 25% ACN, and 25% MeOH.
The terminology ("quasi binary") is awkward, but the practice is fairly common.
Tom, thanks for your goodwill! :wink:
Your information gave me some inspiration and I studied the Drylab software(evaluation), and I found that the ternary isocratic separation model uses this terminology-quasi-binary mixture, but it is not a linear relationship between logarithm of retention(k') and organic concentration, but a quadratic equation. Maybe it really is the amazing point of chemistry! :)
Best regards
Austin
In total there are 29 users online :: 1 registered, 0 hidden and 28 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot] and 28 guests
