I'm particularly interested in IDing the compound with the following dominant mass fragments. It elutes shortly after an 18C long trihydroxyacid.
Base peak: 73
Other dominant ions, in order of abundance: 317, 303, 129, 147, 204, 217, 551. I think 551 is the key.
There is a similar compound that elutes later with 565 instead of 551, so this must be another compound of the same type but with an extra C in the chain.
Please respond directly to Kevin (kem311@psu.edu).
Thanks!
