How several methods in the same sequence over EZChrom 3.1.7
Hello everyone,
I'm an user of EZChrom 3.1.7 software with VWR Lachrom Elite system, a LaChrom Elite HPLC (Diode Array Detector L2455, Autosampler L2200, Pump L2130, EZChrom Elite Cliente/Server Build 3.1.7.11).
I would like to know if it is possible to analyze several vials using different methods in the same sequence of the autosampler in this HPLC. If possible, I want to know the procedure to follow to do it. Because hitherto, I only can use just one method for each sequence.
Could anybody help me?
As far as i know you can specify a different method for each line. Hover your mouse over the most right corner of the method field and click there, the file selection screen Should appear. Note, this is standard behaviour for EZCHROM. Maybe the vwr version vries, but i don't think so.
Freek Varossieau
OpenLab CDS 2 specialist
BeyondOpenLab
beyondopenlab@gmail.com
+5977114721
Users browsing this forum: Semrush [Bot] and 9 guests
