Forced degradation
Why NaOH, HCl, peroxide use for degradation?
Thanks in advance,
Ajay
Many reasons I imagine;
drug will likely come into contact or be in an environment that is acidic, basic or oxidising, this will show you what the products of that will be and then toxicity studies can be done on those products
Hi
not to forget defined lux requirements etcetera, you can find further information at www.ich.org under the Q tab, in the various ICH Q1 guidelines.
NaOH/HCl - To evaluate stability with respect to pH
H2O2 - To evaluate susceptibility to oxidation
