ELSD Troubleshooting
Posted: Wed Nov 17, 2010 7:07 pm
Hello All, I am using a SEDEX ELSD and having an issue with solvent "pooling" at the bottom of the nebulizer. Can somesuggest a solution?
LC101
LC101
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
IIRC the SEDEX 55 I used in the mid/late 90's had that design.Which model?
The newer ones have a downward facing nebuliser with the drain tube at the lowest point.
I've seen that as well as well and also saw that happen if the drain line got crimped.Chek that your solvent drain trap is not so full that liquid isnt draining properly.
