organic acids
We are trying to separate organic acids (complex mixture) with a Ion exclusion column Metrosep Organic Acids in isocratic mode. Somebody already did it? How?
Luciano
N
Luciano:
There are more than a couple ways to solve the separations problem using the Metrosep OA column. I would be happy to send these suggestions to you via email or you can contact me or the Metrohm distributor in Brazil (Pensalab) for direct assistance. I would post the information on this board however it is graphical and reasonably large files.
In essence, the OA column can be used in a suppressed or non-suppressed mode with conductivity detection or using UV as appropriate. I look forward to your satisfactory separation with this column.
Jeff Brewer
Metrohm-Peak
jmb@mp-ic.com
In total there are 23 users online :: 1 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 22 guests
