Carbohidrate Analysis
Posted: Mon Dec 27, 2010 12:03 pm
We have two columns in use for two carbohydratess analysis. One column is a Varian Metacarb 87H Plus and the other is Aminex 87CH from BioRad. the Varian column works with 0.1NH2SO4 at 0.6 ml/min with a temp of 60C. The BioRad column's mobile phase is water and temp. 80C. Flow is 0.6 ml/min.
The que4stion is what happens when switchin from Varian to BioRad. Small cuantities of 0.5N H2SO4 will go inside of the BioRad columns. Somebody knows what happens here?
Thank you for your answer.
Analisis
Analisis
