Menthol Analagesic Quantitation
Posted: Mon Dec 27, 2010 3:55 pm
With very little success, I have endeavored to extract and quant L-Menthol via GC FiD.
The analyte is extracted from a dense creme formulationt that is comprised of waxes, stearyls alcohols, vitamins, fragrances, and glycerins. The chromatography, which I will post as soon as I can get it loaded onto tiny pic, has numerous small regularly occuring little peaks spaced about 30 secs apart from the major peak at 6 mins (which compared to the un-extracted STD sol'n peak also at 6.032 mins.). Why is chrom so decorated with these regular little peaks--which appear even in the un-ext'd STD? I tried to syringe filter via Acrodisk but no success. Is the L-isomer isomerizing? I have not yet ventured to determine if the peaks interfere with quantiation as at this juncture I am at the qualitative i.d. stage of method development. Extraction solvent is dichlormethane. In terms of my sample prep, 1 gram of the ointment cream is disperesd in warm water, then extracted with methylene chloride, then I take this bottom layer and dry over anhydr sod sulf..
Any ideas appreciated from the brain-trust.
