HPLC Column selection for an acid sensitive analyte
I am looking to buy a C18 column, 15 cm, 5 um dp and 4-4.6 id, for my reversed phase HPLC application. The analyte is acid sensitive, therefore, I should work with a mobile phase with a pH of about 8. I was wondering what column I should use to tolerate the alkaline pH range and yet not expensive.
I would certainly appreciate your help.
Sincerely,
Jeegar
Many manufacturers now have columns stable at pH 8. This is not an inclusive list, but:
Waters Xterra
Phenomenex Luna
Agilent Eclipse
come to mind
Agilent Extend and Phenomenex Gemini to name some more...
Dear Tom and Kostas,
Thank you for your response. I will look into them.
Jeegar
