shifting of mass
is it possible, that one compound showing mass in API 2000 DIRECT MASS, BUT NOT SHOWING MASS IN WATERS SINGLE QUDRAPOLE MASS SYSTEM AND WETHER MASS SHIFTS FROM ONE INSTRUMENTS TO OTHER? I.E, M+1 TO M+2 OR ONLY M....................
PLZ REPLY
IS THERE ANY PROCEDURE TO KNOW THAT MY API 2000 SYTEM IS WORKING FINE AND GIVING MASS PERFECT MEANS OK AND RELIABLE?
Have you run a tune or check standard through the instrument. If you run a compund with known masses - they will read either correctly or incorrectly. (Assuming you are using a tuned instrument - my bet is correctly.)
In total there are 27 users online :: 0 registered, 0 hidden and 27 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 27 guests
