5972 Transfer Line Thread Size
Posted: Thu Jan 06, 2011 11:38 pm
I found a die that will clean the brass from the threads on a 5972 transfer line where the column connects. It is size 10NF32.
Chromatography Forum is a public discussion group where you can post questions, news, or messages of interest to chromatographers everywhere, but you must be registered to participate (registration is FREE). If you are a registered user, please log in.
http://chromforum.org/
Size 10 with 32 threads per inch die should be available at your friendly Ace Hardware !!!I found a die that will clean the brass from the threads on a 5972 transfer line where the column connects. It is size 10NF32.
