Baseline increase at the end of running
Posted: Sun Jan 09, 2011 9:10 pm
Hai All members,
I have a problem about chromatograph baseline which always increase at the end of running.
I use GC from Varian serial 3800. I usually do hydrocarbon analysis with
carbon number from C5 to C20 or max C25. I operated the GC with condition
as below:
Temperatures;
Injector: 270 Celcius
Detector: 300 Celcius
Column: initial: 40 for 10 minute, and increase to 270 Celcius with ramp 5 Celcius/min and keep 270 Celcius for 19 minute or 44 minute (total time for running 75 minute or 100 minute)
Column pressure: 10 psi
Amount of sample: 0.2 microlitter
Split ratio: 100
Column specification:
Varian capillary column (CP-sil 5 CB), serial CP7690, 50 m x 0.32 mm, ID 5
micrometer
Any suggestions and helps would be appreciated. Thank you very much.
as below:
Temperatures;
Split ratio: 100
micrometer
