Atmospheric Methane inconsisntent - GC-FID shimadzu GC2014
Posted: Fri Jan 21, 2011 11:52 pm
I've been using a shimadzu GC-2014 to measure ppm levels of methane in the headspace of microcosms (inoculated soil in a vial with a rubber septum). I have been getting fairly clean, consistent results until the past week, where I'm suddenly getting 'fat' peaks (a/h ratio ~6-8, rather than 4 which is what I usually see). This is troubling because these data are inconsistently-inconsistent. Meaning the fat peaks show up in one or two out of three injections for any given sample, and it differs also by the day.
on the 19th, 9/16 injections had wide peaks, and all samples had an unexpectedly high ppm of CH4 (~3.5ppm)
on the 21st, 4/16 injections had wide peaks, all samples had slightly high CH4 levels, (~2.8ppm)
I am completely stumped, as any possible cause I can think of would be something systematic, and I would expect to see a 'consistently inconsistent' change from one day to the next. HELP! Please!!
Some particulars:
I inject 200ul manually with a syringe, but am as careful as possible. withdraw 250ul, express 50ul, inject the remaining 200ul steadily, hit start, count to 5, remove needle. This has served me well up until recently
I have 80/100 porapak q & n column 2m each, ID: 3.2mm
column temp: 50*C
Inj: 60*C
N2/Air carrier: 30ml/min
FID temp: 100*C
sampling rate 40msec
All gasses used are UHP.
Some particulars:
column temp: 50*C
Inj: 60*C
FID temp: 100*C
