2-EHA calculation
Posted: Mon Jan 31, 2011 7:08 pm
by mohammad
Dear All,
I am doing analysis for 2-Ethyl Hexanoic Acid by GC as BP 2009/EP 7.0. Now the problem for me is the calculation part. In EP/BP the calculation part is given as
[Area of sample x Internal std area in standard x standard weight in g x 2] [/area of std x internal std area in sample x sample weight in g ].
Now my question is what is the role of "2" in the calculation part :?:
Plz explain.........
Regards
Mohammad.
Re: 2-EHA calculation
Posted: Tue Feb 01, 2011 7:13 am
by Mr.Buffer
I do not have that monograph at the moment but it is probably dilution of your sample.Probably, it is last extraction volume of your sample.
if you can share your method details , I can answer your question precisely.
Best Regards.
Posted: Tue Feb 01, 2011 8:45 am
by mohammad
Please note the analysis details:
Inernal Std Preparation: Dissolve 100mg of 3-cyclohexylpropionic acid in 100ml cyclohexane. (1.00mg/ml).
Test solution: 0.3g of substance+4.0ml of conc.Hcl+1ml Internal std. shake vigorously for 1 min. allow the phase to settle. Inject upper layer 1.0µL.
Standard Preparation:Dissolve 75.0mg of 2-EHA in internal std & dilute to 50ml with internal standard.
To 1ml of this solution add 4.0ml con.Hcl. shake vigrously for 1 min, allow the phase to settle. Inject upper layer. (1.0µL).
Capillary Column: Stable wax or DA-FFAP.
Calculation:
(Area ratio of sample/ Area ratio of standard) X (standard wt / sample wt) X 2.
Posted: Tue Feb 01, 2011 12:36 pm
by kalidassa
Hi this is Kalidass in the calculation part the 2 is given for dilution of standard and the multiplication of the purity of the 2-EHA. In the method dilution of standard is 0.075g/50 mL. = 100/50=2
Where 100 is the potency of the 2-EHA Standard and 50 is the dilution of the standard 2-EHA solution.
Regards
A.KALIDASS
Posted: Thu Feb 03, 2011 7:44 am
by mohammad
Thnx Mr.Kalidass for the info....
I would like to ask, instead of taking 1 ml of internal std in std and smaple as describe in the monograph, if i take 3 ml, will there be any change in the results, bcz the concentration of std will be different?
Regards
mohammad.
Posted: Thu Feb 03, 2011 10:21 am
by kalidassa
Adding 3 mL of Internal standard in both standard and sample will not differ in the result. Both are resulting is same concentration of 2-EHA. If you want to deviate these things from the monograph then you should validate the same.
I will giving below how the result remains same.
Sample & Standard with 1 mL of internal standard
2-EHA (%) = [(0.075/50)*1/1*1/0.3*100] (Potency of 2-EHA)
= 0.5 %
Sample & Standard with 3 mL of internal standard
2-EHA (%) = 0.075/50*1/3*3/0.3*100 (Potency of 2-ERA)
= 0.5 %
If you adding 3 mL of Internal standard to the sample and 1 mL to standard then the resultant concentration of 2-EHA is now 1.5 %
2-EHA (%) = 0.075/50*1/1*3/0.3*100 (Potency of 2-ERA)
= 1.5 %
Treating the Sample and Standard same will not change in the resultant concentration.
Only the µg/mL will change the µg/g remains as such.
The relation between µg/mL and µg/g is
µg/g= (µg/mL/sample wt in g)* dilution of the sample.
With Best Regards
A.KALIDASS
Posted: Thu Feb 03, 2011 6:33 pm
by mohammad
Once again thnx for clarifying the doubt.....
With respect to test concentration the standard concentration is 0.5% only, where as the limit is 0.8%m/m.
Can you please explain this........... : :?:
Best regards
Mohammad.
Posted: Fri Feb 04, 2011 3:35 am
by kalidassa
Good morning,
I don't know about the specification limit what ever you having. But for the limit 0.8 % we can perform the standard injection at 0.5 %, because if you keeping the limit 0.8% then while doing validation you are going to show the linearity from LOQ Level to 125% or 150% depend on your guideline. Hence we proving our method is linear from LOQ Level to 125% or 150% of specified concentration, we can compare the test solution with any of the standard concentration between LOQ Level to 125% or 150%. It is not compulsory to inject the standard at only specified concentration.
Posted: Fri Feb 04, 2011 7:00 am
by mohammad
Greetings..
Once again thnx for the info....
Regards
Mohammad.
