Phosphate buffer and Fluorescence Detector
I would like to know if I can use a Phosphate buffer (KH2PO4 25mM with 1g of sodium hexansulfonic acid adjusted to pH2 with ortho-Phosphoric Acid) with a flurescence detector W2475?
I know that the cell from the fluorescence detector is smaller than the UV cell so a crystallisation could be very hard to clean?
Does anyone know?
Thanks by advance,
I would expect you would be OK up to about 80% ACN or so (depending on temperature). If you have any precipitation, it will plug your column long before it gets to the detector cell.
In total there are 24 users online :: 2 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 22 guests
