Changing Chromatogram
Hello! I have a problem. I am performing simultaneous quantification of vitamins A, E and D and last week I was able to separate all the peaks. The working conditions were:
mobil phase hexane:isopropanol (99:1), 1ml/min, 290nm. The column is Nucleodur NH2.
This week I tried again and now ganma tocopherol overlap with Vitamin D. I have repited sevaral times and it's the same. I have equilibrated the column for 2 hours before the firs running and I have made fresh solutions. Does anyone knows what is the problem?
Thank you in advanced
hi, how you prepare vitamin E stock solution from viscous standard.
Is the overlap due to wider peaks or to a change in retention?
If it was a change in retention, did all your peaks shift or just one of these?
Wow, I haven't used "normal" phase in three decades. But I remember that the trace water picked up by solvents could be important to causing irreproducibility.
In total there are 32 users online :: 1 registered, 0 hidden and 31 guests (based on users active over the past 5 minutes)
Users browsing this forum: DR and 31 guests
