continuously stirred mobile phase.
In the USP monograph for griseofulvin, it calls for the continuous stirring of a mixture of three miscible solvents (thf, acn, and water).
Why would stirring help?
Thanks, I'm just curious.
MestizoJoe
Analytical Chemist and Adventurer
Venture Industries
Spider-Skull Island
Does USP stand for Unbelievably Sucky Procedures ?
Unintelligible Standard Practices ?
Unnatural Substandard Protocols ?
Most likely originator of the assay procedure stirred his mobile phase, so it was retained. OK: why? Likely when the monograph was written there was not online ternary or quaternary mixing, so such mobile phases were pre-mixed and pumped from one reservoir. User likely felt that stirring either kept it relatively uniform in regards to preferential evaporation through venting, or used stirring/heat/vacuum to keep the mixture from absorbing gases (before in-line vacuum degassers). Many, many USP procedures are woefully out of date.
I agree with Consumer Products Guy. When I was doing HPLC method development in pharmaceutical industry, 95% off all USP methods did not work. It seams that nowadays it is still the same. Don't worry and just use your online degasser.
In total there are 14 users online :: 2 registered, 0 hidden and 12 guests (based on users active over the past 5 minutes)
Users browsing this forum: Google [Bot], Semrush [Bot] and 12 guests
