CN columns for analysis of amines
I was wondering if anyone has experience in using LICHROSPHER 100 CN and/or PHENOMENEX Luna 3u/5u CN columns for analysis of amines?
I was hoping to use for analysis of melamine and its analogs such as cyanuric acid, but I can only buy one CN column, so I wondered if anyone has used them before and can provide feedback.
Thank you.
Not sure why you are using a cyano column, but a quick search on the internet showed quite a few applications on melamine and there were a wide range of columns used : C18, C8, HILIC, Mixed-mode.
Please note CN columns DO NOT last nearly as long as C18s :)
Though I have used neither of the columns you mentioned, I think Type B silica is the way to go. From this point I think Luna would probably be the better choice.
Hi Rwang, thank you for your reply.
I do not wish to use ion pairing agents, so C18 and C8 are out. I am trying out two types of HILIC columns at the same time, but wish to try CN columns as well. Thus, the question. Thanks again!
In total there are 28 users online :: 2 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 26 guests
