HP 5890 Series 2 Plus GC-ECD
How to set up flows for the HP 5890 Series 2 Plus GC-ECD.This one is having EPC. I am using Chemstation A.10.2 soft ware. I need some Help in the window called "Inlet Pressure program", where the inlet pressure and column flows are set up.
You need to elaborate on the issue you're having. Use the Agilent.com Flow Calculator software to determine for the i.d. and length of your column what your inlet pressure should be to get a decent cm/sec flow rate. Then plug in that inlet pressure, and "install" that column choice into the software as well. That's the best starting point.
