Ghost Peak after Column Washing with 0.1% TFA
Dear friends,
I was consistently getting 'ghost peak' and suspected contamination in my column {BEH Shield RP-18 (100x2.1) mm, 1.7 micron}.
I washed the column with A 90% to B 90% for a gradient time of ten minutes, in which A is 0.1% TFA in water and B is 0.1% TFA in acetonitrile. Unfortunately, instead of solving the problem, I got three more ghost peaks. They are now appearing even after washing with 10% aqueous ACN followed by 100% ACN.
Please Help!
Run the "three blank gradients" test to see if the cause is contaminated mobile phase. It's described in the "mini tutorial" in the tophread on the board.
Users browsing this forum: Google [Bot] and 11 guests
