accuracy solutions concentration
the 120% and 80% of nominal concentration for accuracy study has to be exact or approximate concentration is okay?
I believe that's the *minimum* range over which you have to validate.
I think you should target 80 and 120%. And would not need to be exact, we aren't. Usually 90-110% (or tighter) is the spec range for us anyhow for our products.
In total there are 3 users online :: 2 registered, 0 hidden and 1 guest (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 1 guest
