Help with appropriate chromatograph
Posted: Thu Mar 24, 2011 4:10 pm
by akribis2
For all of you chromatography experts out there I will explain my problem below, ANY help you can provide will be of great use.
Firstly I am needing to test petrol with two stroke in it.
I would also like to get measurements on oxygenates, methanol and ethanol
Can anyone tell me if either of these two pieces of equipment will accomplish this?
Perkin Elmer Model 9000
Hewlett Packard 5880A
ANY HELP WILL BE GREAT
Thank you for your time!
Stefan[/size]
Re: Help with appropriate chromatograph
Posted: Thu Mar 24, 2011 7:43 pm
by JGK
For a start both these machines are Gas Chromatographs so posting in the correct forum might help.
Posted: Fri Mar 25, 2011 1:24 am
by AICMM
akribis2,
I am not afraid of old GC's but these are really, really old GC's. Could you at least find a 5890 or Autosystem to work with? Having said that, the question you ask also requires that you know some other things, such as what detectors you are looking to use (FID almost a requirement) and how you intend to inject samples (since this can dictate the injection system.) Furthermore, in regards to your oxygenates requirements, you need to know what other interferences are likely to be present since these may require that you valve the system for selectivity. Things can get complicated relatively quickly and you are asking about very old systems that could be very hard to correctly fit out.
Best regards,
AICMM
Posted: Fri Mar 25, 2011 1:32 am
by chromatographer1
Stefan,
These are indeed two classic gas chromatographs.
The analysis you require is usually performed by multidimensional gas chromatography analyzers.
The difference (using an automobile comparison) is like comparing a 1908 Oldsmobile with a 2011 Prius.
There is more involved than I can type in 5 minutes on this computer.
best wishes,
Posted: Fri Mar 25, 2011 9:23 am
by akribis2
Hi I understand that these are relatively old machines, but thank you for all of your help and information!
You may be hearing from me again
Posted: Thu Apr 21, 2011 11:43 am
by akribis2
To those who had some input, Thanks for your info, after a few weeks research I have found the right chromatography equipment!
Thank you all for your help!
Used Laboratory Equipment
Posted: Thu Apr 21, 2011 4:20 pm
by aldehyde
Your username is akribis2 and the link you keep posting is to a used instrument supplier at akribis.co.uk.
thats kind of weird..
Posted: Tue Apr 26, 2011 8:42 am
by akribis2
Really its weird to have someone in an industry looking for information on equipment he sells?
How peculiar
Posted: Tue Apr 26, 2011 8:59 am
by DSP007
Stefan[/size]
Maestro, trim the march! (с)
What problem is so great a panic that requires
any help?
Sit down, please, and planted what symptoms you suffer...
PS .
The ability of the device to perform tasks depends primarily on its technical condition and the correctness of the sample preparation.
Here, as in motor racing - the most important detail of car-strip between the handlebars and seat. (c)
PPS
To buy or not to buy- What is questions ? (Parody of Shakespeare)
