HP 1090 leak shutdown
Hi, i have a leak shutdown in my HP 1090. every thing is running good for about 1 min and later on I have a leak shutdown. Any help
If you mean a fluid leak, then check the sensor in the column compartment, most leaks occur there. These must be dry; if wet, soak up the fluid and let air dry, then turn on again.
Second would be to make sure the autosampler isn't leaking at its needle/seat or at its rotor valve, if so, check its leak sensor as above.
In total there are 23 users online :: 1 registered, 0 hidden and 22 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 22 guests
