Macro program for Agilent Chemstation
Hello all,
Can anybody provide a Macro program to print injection logs? This is Agilent MS ChemStation version E.02.00.493. Thanks a lot.
If you go to
http://www.chemuserworld.com/forum/view ... php?tid=14
and download the excel spread sheet, this will create a list of injections, and the output can be adjusted.
N.B. Macros in Excel need to be enabled for the spread sheet to work (security setting tab).
you need to go into the xxx.d folder and double click on the data.ms file, the spread sheet will generate the rest.
You need to have MS Excel installed on the PC, or map the data directory to a PC with MS excel installed on it. (MS ExcelViewer will not run the VBA script.)
Alex
Thank you for your reply. It works very well.
In total there are 27 users online :: 1 registered, 0 hidden and 26 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot] and 26 guests
