SF6 analysis with TCD - Baseline failure after O2 peak
Posted: Thu Apr 14, 2011 8:38 am
Hi all
I'm a PhD student, analysing for SF6 using an old Shimadzu 8A TCD GC connected to a spectra-physics 4290 integrator. I'm running column at 55 degrees and N2 carrier gas at a flowrate of 15ml/min. I am using a K2CO3 trap to prevent against water incursion into the GC.
I have a problem with the O2 peaks when putting manual injections through the GC. When a pure standard (SF6 in N2) is used, this problem disappears due to low O2 contamination. However, when I inject a sample of SF6 in air, the baseline fails to return level after the (negative) O2 peak. As a result it swallows the SF6 peak and gives an erroneous area value.
On the next run the baseline will drift back down again slowly then climb rapidly again after the next O2 peak.
Any ideas?
Any ideas?
