Mobile phase of HPLC
I am trying to test concentration of nitrate and nitrite by HPLC Agilent 1200. I am using column ODS Hypersil column. I had tried 70% methanol and 30% water as my mobile phase, but the retention time is different for various concentration standard solution. Does this means that I used wrong mobile phase?
Can anybody suggest me what the mobile phase that I should used?
What a "nitrates and nitrites" - organic (class- alifatic, aromatic , geterocicles, others, any functional grops - amines, acids, phenols,amides , other) or inorganic?
If inorganic -"shotguns do not clean brick (с)" . Need use anionic sorbent.
I use sodium nitrate which is inorganic compound. Can suggest what kind of anionic solvent as my mobile phase?
Your best option would be an anion exchange column. Look at the sites of Dionex and Metrohm for these.
In total there are 16 users online :: 0 registered, 0 hidden and 16 guests (based on users active over the past 5 minutes)
Users browsing this forum: No registered users and 16 guests
