Cleaning IEX resins
What's up guys
I purify a lot of cytokines expressed in E. Coli for a production lab and I had a question about cleaning the IEX resins.
I'm getting brown crude at the top of my resin when I do large scale batches. My impression is that this is lipid contamination.
How do I get rid of it? I don't want to throw out my resin
Joey
A sample prep step in which your sample is passed over glass might help. Glass tends to adsorb lipids (but also some proteins, so be careful). You could pack a large column with glass wool, or very small glass beads, and possibly even use it in-line as a sort of guard column.
Scott Horn
Scott Horn
That could be good preventative care, but I'm wondering if there is a way to save my resin that has already been contaminated. I pipette the brown resin off and save it, but I can't clean it enough with 1M NaOH or 20% EtOH to get the color back...
Is there another solvent or trick I could use?
Joey
In total there are 14 users online :: 2 registered, 0 hidden and 12 guests (based on users active over the past 5 minutes)
Users browsing this forum: Bing [Bot], Semrush [Bot] and 12 guests
